Visualizing contours in only one specified surface
Dear all,
I have a 3D model composed of only one subdomain enclosed by a very large number of surfaces. The problem is that whenever I plot the results using Surface (4.1) or Boundary (3.5a) I get the plots for all surfaces. I guess this should be really easy, but I can't figure how to plot the contours in just one (user-defined) certain boundary, just like when you create a user-controlled mesh boundary by boundary. I'm not interested in slice/isosurface/etc, just the results in one boundary while the rest is shown as wireframe. I wouldn't believe this is not possible.
Thank you in advance !
Néstor
1 Reply Last Post 27 janv. 2011, 13:16 UTC+1
Posted: 1 decade ago 27 janv. 2011, 13:16 UTC+1
I just found how to do it in 4.1. Simply Right-click on the Data Sets, make a surface, and choose this new Data Set on your Surface Plot. As I said, it had to be easy.
regards
Néstor
I just found how to do it in 4.1. Simply Right-click on the Data Sets, make a surface, and choose this new Data Set on your Surface Plot. As I said, it had to be easy. regards Néstor
