Volume Expansion
I'm modeling Volume expansion of a disk shaped material.
I have used a ODE with this Expression :
v-vt=0
v=Vol1 , initial
But I got some errors
Failed to evaluate variable Jacobian.
- Variable: vt
- Global scope
4 Replies Last Post 8 févr. 2011, 16:25 UTC+1
Posted: 1 decade ago 28 janv. 2011, 14:22 UTC+1
Could itbe that you are in structural and that v and vt are already used by COMSOL ?
Always use "private names, most 1-2 letter names are already used by COMSOL, sometimes you want to redefine them, but often it gives errors, as you need to know exactly what you are doing
Hi Could itbe that you are in structural and that v and vt are already used by COMSOL ? Always use "private names, most 1-2 letter names are already used by COMSOL, sometimes you want to redefine them, but often it gives errors, as you need to know exactly what you are doing -- Good luck Ivar
Posted: 1 decade ago 28 janv. 2011, 14:26 UTC+1
Thanks a lot for you reply.
I'm not using Structural. I have chosen ODEs and DAEs.
I have attached the Model.
I'd appreciate it if you could take a look.
Thanks a lot for you reply. I'm not using Structural. I have chosen ODEs and DAEs. I have attached the Model. I'd appreciate it if you could take a look.
Posted: 1 decade ago 29 janv. 2011, 19:04 UTC+1
you cannot try to solve for an ODE alone as you have not defined any dependent variables What is v ?, and vol1 ?
You need to define some physics via an PDE and possibly add an ODE if required
Hi you cannot try to solve for an ODE alone as you have not defined any dependent variables What is v ?, and vol1 ? You need to define some physics via an PDE and possibly add an ODE if required -- Good luck Ivar
Posted: 1 decade ago 8 févr. 2011, 16:25 UTC+1
Ivar is right (of course!).
But you can in fact solve an ODE, as a global space independent problem. You to define the dependent variable, as Ivar points out, and you can do this by setting Name to v in the Global Equations settings, also, change vol1 to 0 or something else that is defined.
If you want to solve a distributed ODE on a 2D domain (where sources may change with position, but you have no gradient driven transport), use rather a General form PDE and only use the f and da terms.
Niklas
Ivar is right (of course!). But you can in fact solve an ODE, as a global space independent problem. You to define the dependent variable, as Ivar points out, and you can do this by setting Name to v in the Global Equations settings, also, change vol1 to 0 or something else that is defined. If you want to solve a distributed ODE on a 2D domain (where sources may change with position, but you have no gradient driven transport), use rather a General form PDE and only use the f and da terms. -- Niklas
