8 févr. 2011, 16:46 UTC+1
normally you use the new 4.1 N turn coil BC that is set up for that, without drawing all the individual wires, which would make a meshing going rapidly above normal RAM limits
8 févr. 2011, 22:25 UTC+1
Hi Ivar,
Thanks for your useful information. First i have to clarify one thing. You want me to use 3D or 2D axisymmetric. can i find N turn coil BC function in 3D( mef ) ? Thanks for your help.
Raj
Hi Ivar,
Raj
9 févr. 2011, 07:47 UTC+1
you are right the ultiturn domain BC are only in 2D and 2D axi, you must add them by hand yourself (via the equations) in 3D. In anycase 2D-axi is always adviceable, when possible, at least until you haveing a working mode, then one can port it to 3D as often there is easily factor 10 in processing time
9 févr. 2011, 11:38 UTC+1
Hi Ivar,
My simulation is almost same but the thing is my coils are normal copper wires(Not litz wires). I have two coils of 10 turns and wire thickness .25mm. I have give 1A current at 1MHz is given into coil one and i have to observe the induced current, proximity and skin effect. Can any boby help me how to start. I have some basic idea. I am attaching my model. Thanks for all.
Pranith Tummala
Hi Ivar,
Pranith Tummala
