9 years ago
12 avr. 2017, 12:04 UTC−4
You will find a list of commonly used piezoelectric materials included with your Comsol installation. Each piezoelectric material has values for the compliance, coupling, and permittivity matrices. You only need to enter these manually if (1) you are using an unusual material or (2) you think the built-in parameters are wrong.
A common mistake is NOT making non-piezo materials linear elastic. When this is done Comsol prompts you for permittivity and coupling matrix for steel or such, which makes no sense.
D.W. Greve
DWGreve Consulting
D.W. Greve
DWGreve Consulting
9 years ago
12 avr. 2017, 14:24 UTC−4
D.W. Greve
DWGreve Consulting
Thank you D.W. Greve for the response.
We have an ultrasound transducer and when we asked the manufacturer for piezoelectric properties, we only got density, elastic stiffness, dielectric constant, electromechanical constant, and thickness. Is there any way that I could calculate permittivity and coupling matrix from provided info?
[QUOTE]
D.W. Greve
DWGreve Consulting
[/QUOTE]
9 years ago
12 avr. 2017, 23:56 UTC−4
Many- maybe most- commercial transducers use some variety of PZT (Lead zirconate titanate). Different types (designated PZT-4, PZT-5A, etc.) differ in permittivity and coupling factor. You MIGHT be able to match up the permittivity with one of the types included in COMSOL. Good agreement with electromechanical coupling factor would be a further confirmation, but then you must be careful to use the right electromechanical coupling factor (it depends on direction, probably more than permittivity).
This only allows you to make a good guess and sometimes manufacturers use special mixtures or even different materials.
Details of transducer construction are regarded as proprietary by manufacturers, so you may not be able to get much more information.
DWGreve
DWGreve
