laminar flow
Sir
When iam simulating for laminar flow iam getting this error
- Detail: Undefined value found in the equation residual vector.
There are 37309 degrees of freedom giving NaN/Inf in the vector for the variable mod1.u
at coordinates: (0.0019,0.000979,0.000978), (0.0019,0.000779,0.000978), (0.0019,0.000879,0.000978), (0.0019,0.000916134,0.000911068), (0.0019,0.000853269,0.000844136), ...
There are 37309 degrees of freedom giving NaN/Inf in the vector for the variable mod1.v
There are 37309 degrees of freedom giving NaN/Inf in the vector for the variable mod1.w
Kindly tell me the way to delete this error
kartikeya
2 Replies Last Post 19 août 2011, 00:12 UTC+2
Posted: 1 decade ago 16 févr. 2011, 07:30 UTC+1
I suspect that you are missing some material parameters, check carefully your material node and see if there is not a "red flag" somewhere. You should always recheck your material nodes (all of them) after having set up your model, as
if you change some physics parameters this demands different sets of material parameters
Hi I suspect that you are missing some material parameters, check carefully your material node and see if there is not a "red flag" somewhere. You should always recheck your material nodes (all of them) after having set up your model, as if you change some physics parameters this demands different sets of material parameters -- Good luck Ivar
Posted: 1 decade ago 19 août 2011, 00:12 UTC+2
Kartikeya,
Could you fix that problem?
J.W
Kartikeya, Could you fix that problem? J.W
