gaussian beam in Laser Heating of a Silicon Wafer
Hi i refer to the tutorial of laser heating on silicon wafer for Comsol 5.3: www.comsol.com/model/download/383241/models.mph.laser_heating_wafer.pdf
In the tutorial the gaussian beam profile was given in the following equation:
(p_laser/(2*pi*r_spot^2))*exp(-r_focus^2/(2*r_spot^2))
How was this equation derived? from literature most gaussian beam profile are given in the following instead:
((2*p_laser)/(pi*r_spot^2))*exp(-(2*r_focus^2)/r_spot^2)
I tried finding the forum but there is nothing written about this.
1 Reply Last Post 19 mai 2017, 15:48 UTC+2
Walter Frei COMSOL Employee
Posted: 8 years ago 19 mai 2017, 15:48 UTC+2
Dear Joel,
You're correct, this example was using a normalization of the Gaussian that isn't typical in the literature (although it did still give the correct total heat load.) Thank you for reporting this. The updated model is available here:
www.comsol.com/model/laser-heating-of-a-silicon-wafer-13835
Best Regards,
Dear Joel, You're correct, this example was using a normalization of the Gaussian that isn't typical in the literature (although it did still give the correct total heat load.) Thank you for reporting this. The updated model is available here: https://www.comsol.com/model/laser-heating-of-a-silicon-wafer-13835 Best Regards,
