Connect SMA conectors to MW source
Hello
Please, id like examinate microwave propagation in sma connector pcb mount. (from comsol library). I connected lumped port on middle circle and make inner and outer cylinder like perfect electric conductor, but there is still error "Uniform lumped port should be placed between two conductive boundaries."
Do you know where can be probleme? This is same when I make all boundaries like perfect electric conductor, probleme is still here.
Thanks a lot for advice
1 Reply Last Post 19 mai 2017, 20:23 UTC+2
Posted: 8 years ago 19 mai 2017, 20:23 UTC+2
Change from uniform to coaxial in the drop down menu for the lumped port.
