Model a torsion hinge connecting two beams
Hi, I am simulating the harmonic response of a structure composed of the following things :-
1) A beam
2) A torsion hinge
3) Another beam
The beams are Euler-Bernoulli. My model is 2D. I am unable to model the torsion hinge. I created the multibody physics study . Initially, I created a hinge joint. And added a "spring and damper" thing with k_theta (torsion coefficient) . But I was unable to select the boundaries of the two beams to form the hinge. For some reason, the domain selection gets turned on and I am unable to select the boundaries of the beams.
I tried using the rigid connector but that did not work as well. Please help I am pressed for a deadline!
0 Replies Last Post 23 mai 2017, 23:52 UTC+2
Hello Aditya S Nanda
