Eddy Curents in coil group domain
I'v worked some days with comsol 4.1 and h'v tried multiturn, singleturn and coil-group-domain conditions in 2D axialsymetric. There is skin and proximity effect and I think it works good. Eddy currents in additional domains works also fine. But how to set up the right conditions for some domains (wich schould be a coil-group-domain) to get eddy curents in an coil in 2D axialsymetric. Hope you understand my request.
Thanks a lot.
2 Replies Last Post 24 févr. 2011, 15:58 UTC+1
Posted: 1 decade ago 24 févr. 2011, 15:23 UTC+1
two comments, one on your geometry, if your coil "touches", you have a contact point that is not very clearly defined, I would keep them "just not touching"
for the induced current I would look at "mef.Jiphi" and not "mef.normJ"
check the underlaying equations
Hi two comments, one on your geometry, if your coil "touches", you have a contact point that is not very clearly defined, I would keep them "just not touching" for the induced current I would look at "mef.Jiphi" and not "mef.normJ" check the underlaying equations -- Good luck Ivar
Posted: 1 decade ago 24 févr. 2011, 15:58 UTC+1
Hi Ivar, thanks for your quick reply and the advice with the "touches". That was not intended. I'll check the "mef.Jiphi".
Thanks a lot.
Hi Ivar, thanks for your quick reply and the advice with the "touches". That was not intended. I'll check the "mef.Jiphi". Thanks a lot.
