Add an electrical circuit to a coil
Posted 7 juil. 2017, 10:55 UTC+2 Low-Frequency Electromagnetics 0 Replies
I'm simulating a PM generator and I'm getting a voltage using the multi-turn coil node , and I can only get them separately , the voltage by considering an open circuit and the current by a short circuit .so I want to use an electrical circuit composed of ground node,External I Vs U and a 20Ω resistor .is this correct ? because there is also the Rj of the electrical circuit (Resistance in parallel to pn jonctions) what is it ?
If you have any suggestions about this point I will be immensely grateful.
Sincerely,
Moumen
Hello Abdelmoumin Allioua
