Frequency-dependent loading with parametric sweep
I am doing a Harmonic Analysis, but what I really want to is to apply a frequency sweep but with different boundary loads for each frequency.
Does anyone know if this is possible.
Many thanks
3 Replies Last Post 11 mars 2011, 07:33 UTC+1
Posted: 1 decade ago 9 mars 2011, 16:59 UTC+1
the frequency sweep parameter is "freq" so why not, on a simple model you can predict analytically, you add a BC condition linked to "freq" or omega=2*pi*freq
Hi the frequency sweep parameter is "freq" so why not, on a simple model you can predict analytically, you add a BC condition linked to "freq" or omega=2*pi*freq -- Good luck Ivar
Posted: 1 decade ago 10 mars 2011, 17:22 UTC+1
Thanks Ivar,
I am still not clear on how to implement this. Instead of carrying out separate runs at each frequency using different amplitudes, I want to tell do a parameter sweep but tell comsol at each frequency to use a different amplitude which I will supply. This will save a whole load of time. I am not sure how to actually implement this in Comsol.
Cheers
Thanks Ivar, I am still not clear on how to implement this. Instead of carrying out separate runs at each frequency using different amplitudes, I want to tell do a parameter sweep but tell comsol at each frequency to use a different amplitude which I will supply. This will save a whole load of time. I am not sure how to actually implement this in Comsol. Cheers
Posted: 1 decade ago 11 mars 2011, 07:33 UTC+1
I'm not sure I catch you:
a) use a double parametrical sweep
b) define V(freq) and set up an analytical or interpolated function such that V(freq) takes the shape at the given frequency as you want
Hi I'm not sure I catch you: a) use a double parametrical sweep b) define V(freq) and set up an analytical or interpolated function such that V(freq) takes the shape at the given frequency as you want -- Good luck Ivar
