How to check thermal wave speed in comsol v 4.1??
Is the heat transfer x velocity give the thermal wave speed??/
Pls reply.
Refgards!!!
Deepak
1 Reply Last Post 10 mars 2011, 07:58 UTC+1
Posted: 1 decade ago 10 mars 2011, 07:58 UTC+1
I believe you need to reformulate your question slightly, because foe me a heat dissipation equation cannot generate a "wave", it's not in the PDE. And do not mix the d/dx (or y,z) and d/dt
Hi I believe you need to reformulate your question slightly, because foe me a heat dissipation equation cannot generate a "wave", it's not in the PDE. And do not mix the d/dx (or y,z) and d/dt -- Good luck Ivar
