My model seems too sensitive to the mesh
Posted 7 août 2017, 21:05 UTC+2 Heat Transfer & Phase Change, Geometry, Mesh, Studies & Solvers Version 4.4 1 Reply
On one face I have a heat input, and on another I have convective heat transfer with various heat transfer coefficient distributions. The distributions are dependent on things such as heat flux, so it is a highly non-linear problem. I have meshed one end using quad elements and swept the mesh along the length of the geometry. These quad elements are further split into triangles on the face with convective heat transfer.
The issue that has me puzzled at the moment is the sensitivity of the model to the mesh size. If I split the geometry into 20 divisions lengthwise, for example, it will solve. If I refine the mesh to 40 divisions, it won't solve. If I further refine to 50, it will solve. 70 might not solve, but 75 might. Due to this irregularity I have a very difficult time getting a solution with an acceptable mesh. I don't really understand this. Does anyone have any ideas?
Thank you,
Bryan
Thank you,
Bryan
1 Reply Last Post 9 août 2017, 19:24 UTC+2
