How to apply a space and time dependent boundary condition?
Hi everyone,
I am trying to apply a sinusoidal prescribed displacement to the edge of a plate for 5 periods of the signal.
The applied signal has the form of F1(y,t)=u1(y)cos(2.pi.f0.t)+u2(y)sin(2.pi.f0.t) for prescribed component in x direction and F2(y,t)=v1(y)cos(2.pi.f0.t)+v2(y)sin(2.pi.f0.t) for prescribed component in y direction.
The variable y is associated with the mesh grid, i.e. the values of y are the values of the node positions along the extremity of the plate.
The four functions u1, u2, v1, v2 are interpolation functions which the discrete data sets I already have.
Is there any possible way to set up this kind of boundary conditions in COMSOL? I really appreciate if anyone can help me with this troublesome issue.
Bests,
Ngoc
4 Replies Last Post 24 oct. 2017, 11:24 UTC+2
Posted: 8 years ago 19 oct. 2017, 16:01 UTC+2
Hi Ngoc,
Basically, you just type in the expressions in the text fields for the prescribed displacements.
u1(y)*cos(2*pi*f0*t)+u2(y)*sin(2*pi*f0*t)
f0 can be defined as a parameter.
For a more general discussion of how boundary conditions can be modified, see also
https://www.comsol.se/blogs/how-to-make-boundary-conditions-conditional-in-your-simulation/
Henrik
Henrik Sönnerlind
COMSOL
Hi Ngoc, Basically, you just type in the expressions in the text fields for the prescribed displacements. u1(y)\*cos(2\*pi\*f0\*t)+u2(y)\*sin(2\*pi\*f0\*t) f0 can be defined as a parameter. For a more general discussion of how boundary conditions can be modified, see also https://www.comsol.se/blogs/how-to-make-boundary-conditions-conditional-in-your-simulation/ Regards, Henrik
Posted: 8 years ago 23 oct. 2017, 14:17 UTC+2
Hi Henrik,
Thank you for answering my question. I have applied the prescribed BCs for my model and it worked when I used only Solids Mechanics physic. However, when I added Electrostatic and Piezoelectric effect for time analysis, COMSOL could not find converged solutions. Can you help me figure out where I did it wrong? I attached both models (before and after the electrostatic physic is added) here.
Bests,
Ngoc Nguyen
Hi Henrik, Thank you for answering my question. I have applied the prescribed BCs for my model and it worked when I used only Solids Mechanics physic. However, when I added Electrostatic and Piezoelectric effect for time analysis, COMSOL could not find converged solutions. Can you help me figure out where I did it wrong? I attached both models (before and after the electrostatic physic is added) here. Bests, Ngoc Nguyen
Posted: 8 years ago 23 oct. 2017, 17:09 UTC+2
Hi Ngoc,
The first sanity check would be that the electric problem is grounded somewhere.
Regards, Henrik
Henrik Sönnerlind
COMSOL
Hi Ngoc, The first sanity check would be that the electric problem is grounded somewhere. Regards, Henrik
Posted: 8 years ago 24 oct. 2017, 11:24 UTC+2
Hi Henrik,
Yes, it is indeed due to the lack of electrical boundary conditions. The simple plate model works now. I am moving on to a more complicated structure. Thank you and have a good day.
Bests,
Ngoc
Hi Henrik, Yes, it is indeed due to the lack of electrical boundary conditions. The simple plate model works now. I am moving on to a more complicated structure. Thank you and have a good day. Bests, Ngoc
