Frquency domain modal analysis
Hi!
I am performing a frequency domain modal analysis and would like to evaluate the contribution of the different eigenmodes to my forced response. Of course I can run the modal solver for each eigenpair and check the response, but that is very time consuming... Is there any way to run the modal solver for all eigenpairs and then generate a plot where the result for the different eigenpairs are plot separately? I would be very grateful for any input, suggestion or idea on this. Thanks!
2 Replies Last Post 25 oct. 2017, 11:28 UTC+2
Posted: 8 years ago 23 oct. 2017, 17:02 UTC+2
Hi Hanna,
You can place the modal analysis inside a parametric sweep, where the sweep parameter is the mode number.
The eigenfrequnecy analysis should then be done in separate study so that it is not repeated inside the parametric sweep.
Regards, Henrik
Henrik Sönnerlind
COMSOL
Hi Hanna, You can place the modal analysis inside a parametric sweep, where the sweep parameter is the mode number. The eigenfrequnecy analysis should then be done in separate study so that it is not repeated inside the parametric sweep. Regards, Henrik
Posted: 8 years ago 25 oct. 2017, 11:28 UTC+2
Thank you Henrik! Such an easy solution that I hadn't thought about - it works perfect!
Best Regards Hanna
Thank you Henrik! Such an easy solution that I hadn't thought about - it works perfect! Best Regards Hanna
