Problem solving a flow with inlet pressure
Posted 22 nov. 2017, 09:16 UTC−5 2 Replies
I have to model a flow of Helium inside a micronozzle (inlet diameter = 5 mm and outlet diameter = 1mm) and all I am given is the inlet pressure (30 bars), and the pressure at the other side of the micronozzle is ambiant pressure. The tube is 23 mm. The issue I'm facing is that the solver can't find a solution if I just put an inlet and outlet with pressure, no viscous stress as BC. I tryied both laminar and turbulent flow.
I know it has been discussed a few times in the forum but I wasn't able to find a thread resolving my problem. I don't know if I missed something in comsol or simply with the actual phenomena.
If someone knows what I could do step by step, Thanks in advance!
