Time dependent vs frequency domain study
Hello, I am doing a time dependent study for piezoelectric material. At the terminal boundary condition I put : V00.sin(2.pi.frq.t) where frq is the excitation frequency and V00 is the terminal voltage amplitude. In order to check the steady state value of the previous study, I performed a frequecy domain study where I replace the above input of the terminal boundary condition by V00. In this study's settings, I put frq in the checkbox labeled Frequencies. The amplitude result is largely different between both studies (5µm at steady state for time dependent and 0,25µm for frequency domain). There must be an error somewhere but I can't find it! Any help will be appreciated. Thanks in advance, Khaled HARMOUCH
4 Replies Last Post 7 déc. 2017, 08:30 UTC−5
Posted: 8 years ago 7 déc. 2017, 06:27 UTC−5
Hello Khaled,
which is the length of the pulse in time domain?
Marco
Hello Khaled, which is the length of the pulse in time domain? Regards, Marco
Posted: 8 years ago 7 déc. 2017, 08:04 UTC−5
Hello Marco,
The time legth is 500/frq ( ~15ms) with a time step of 0.05/frq (1.5µs).
Sincerly,
Khaled
Hello Marco, The time legth is 500/frq ( ~15ms) with a time step of 0.05/frq (1.5µs). Sincerly, Khaled
Posted: 8 years ago 7 déc. 2017, 08:25 UTC−5
Have you tried to input the rms valueof the wave in the frequency study?
Posted: 8 years ago 7 déc. 2017, 08:30 UTC−5
Due to the large difference between time dependent and frequency studies (5µm and 0,25µm).
I dont see that putting rms value might change dramatically the result!
Plus the rms value tends to decrease the displacement, therefore increase the difference between two results
Can you develop more your idea?
Regards
Khaled
Due to the large difference between time dependent and frequency studies (5µm and 0,25µm). I dont see that putting rms value might change dramatically the result! Plus the rms value tends to decrease the displacement, therefore increase the difference between two results Can you develop more your idea? Regards Khaled
