29 mars 2011, 21:20 UTC+2
have you checked the model builder in the mems section, there is a film damping example, cannot remember if it was frequency sweep (believe so) or only eigenfrequency analysis
1 avr. 2011, 07:32 UTC+2
Hi Ivar,
I have found one example on squeeze film, but it is on a transient problem.
Siddhartha
Hi Ivar,
Siddhartha
3 avr. 2011, 12:02 UTC+2
I want to find out frequency response of a squeeze film with structure. Can anybody help me with existing module or instructions?
Siddhartha
Siddhartha
2 nov. 2011, 16:32 UTC+1
Hi Siddhartha,
Did you find a solution?
I also want to do squeeze-film damping frequency response. Mostly I just want to model the quality factor.
The other problem is, I have an arbitrary geometry. The model in the Comsol Model Library uses the math to assume the air is squeezed out only at the edges -- if you add periodic holes then you have to use different math to assume that the air is squeezed out the holes. (So you can see what I mean, go here:
www.comsol.com/multiphysics/slidingfilms/, download the pdf for the model, and look on Page 2 where it references Ref 3).
However Ref 3 only includes periodic holes. I have a funny arbitrary geometry...
Any ideas?
Hi Siddhartha,
The other problem is, I have an arbitrary geometry. The model in the Comsol Model Library uses the math to assume the air is squeezed out only at the edges -- if you add periodic holes then you have to use different math to assume that the air is squeezed out the holes. (So you can see what I mean, go here: http://www.comsol.com/multiphysics/slidingfilms/, download the pdf for the model, and look on Page 2 where it references Ref 3).
Any ideas?
