minimum between two variables
Hi, I'm performing a simulation using the Heat Transfer in Fluids and Laminar Fluid Flow modules. In my problem, the viscosity is governed by two different equations. I need to impose that the dynamic viscosity (n) to be used (imposed as user defined in the Laminar Flow under Fluid Properties) is the minimum value between the two viscosities calculated according to the two different equations, something like:
n=min(nT,nY)
I wonder if this is the correct way to ask Comsol to calculate the minimum between two variables or not.
Thank you, all the best, Valentina
5 Replies Last Post 8 janv. 2018, 20:37 UTC+1
Posted: 8 years ago 21 déc. 2017, 17:05 UTC+1
Good guess! See Reference Manual for COMSOL Multiphysics, version 5.3a, page 244. All documentation is accessible through File > Help > Documentation.
Jeff Hiller
Good guess! See Reference Manual for COMSOL Multiphysics, version 5.3a, page 244. All documentation is accessible through File > Help > Documentation. Jeff
Posted: 8 years ago 26 déc. 2017, 18:43 UTC+1
Hi, I checked on the documentation for Comsol 5.3, but I don't understand if the expression MIN can be used in my case, since the arguments are variables. I read that there is also ATTIMEMIN, but I think is not useful for my case, since I need to define the viscosity imposed as user defined in the Laminar Flow under Fluid Properties as the minimum between the two variables. It's not a result evaluation. I tried to run the code using n=min(nT,nY), but the simulation gives error after a while during the calculations.
Thanks, Valentina
Hi, I checked on the documentation for Comsol 5.3, but I don't understand if the expression MIN can be used in my case, since the arguments are variables. I read that there is also ATTIMEMIN, but I think is not useful for my case, since I need to define the viscosity imposed as user defined in the Laminar Flow under Fluid Properties as the minimum between the two variables. It's not a result evaluation. I tried to run the code using n=min(nT,nY), but the simulation gives error after a while during the calculations. Thanks, Valentina
Posted: 8 years ago 2 janv. 2018, 15:17 UTC+1
Hello Valentina,
Min should work even for variables, so I suspect the source of your problem is somewhere else. I recommend you contact COMSOL's support team at support@comsol.com .
Jeff Hiller
Hello Valentina, Min should work even for variables, so I suspect the source of your problem is somewhere else. I recommend you contact COMSOL's support team at support@comsol.com . Best, Jeff
Posted: 8 years ago 7 janv. 2018, 11:58 UTC+1
Thank you so much, all the best, Vale
Posted: 8 years ago 8 janv. 2018, 20:37 UTC+1
Updated: 8 years ago 8 janv. 2018, 20:39 UTC+1
Hi, I got this error when I try to run the model:
Velocity u, Pressure p Attempt to evaluate negative power of zero. - Function: ^ Failed to evaluate temporary symbolic derivative variable. - Variable: epII@VDN$mod.ux - Defined as: (0.5((0.5((((2(((ep12^2)+(ep13^2))+(ep23^2)))+(ep11^2))+(ep22^2))+(ep33^2)))^(-0.5)))(0.5(2ep11)) Failed to evaluate temporary symbolic derivative variable. - Variable: nb@VDN$mod.ux - Defined as: (((0.5((0.5((((2(((ep12^2)+(ep13^2))+(ep23^2)))+(ep11^2))+(ep22^2))+(ep33^2)))^(-0.5)))(0.5(2ep11)))1.4142135623730951)((-(c0-(((fcrho)g)z)))/((epII1.4142135623730951)^2)) Failed to evaluate temporary symbolic derivative variable. - Variable: n@VDN$mod.ux - Defined as: (nT>nb)((((0.5((0.5((((2(((ep12^2)+(ep13^2))+(ep23^2)))+(ep11^2))+(ep22^2))+(ep33^2)))^(-0.5)))(0.5(2ep11)))1.4142135623730951)((-(c0-(((fcrho)g)z)))/((epII1.4142135623730951)^2))) Failed to evaluate temporary symbolic derivative variable. - Variable: mod.spf.mu@VDN$mod.ux - Defined as: (nT>nb)((((0.5((0.5((((2(((ep12^2)+(ep13^2))+(ep23^2)))+(ep11^2))+(ep22^2))+(ep33^2)))^(-0.5)))(0.5(2ep11)))1.4142135623730951)((-(c0-(((fcrho)g)z)))/((epII1.4142135623730951)^2))) Failed to evaluate temporary symbolic derivative variable. - Variable: mod.spf.mu_eff@VDN$mod.ux - Defined as: (nT>nb)((((0.5((0.5((((2(((ep12^2)+(ep13^2))+(ep23^2)))+(ep11^2))+(ep22^2))+(ep33^2)))^(-0.5)))(0.5(2ep11)))1.4142135623730951)((-(c0-(((fcrho)g)z)))/((epII1.4142135623730951)^2))) Failed to evaluate temporary symbolic derivative variable. - Variable: mod.spf.K_stress_tensorxz@VDN$mod.ux - Defined as: (mod.uz+mod.wx)((nT>nb)((((0.5((0.5((((2(((ep12^2)+(ep13^2))+(ep23^2)))+(ep11^2))+(ep22^2))+(ep33^2)))^(-0.5)))(0.5(2ep11)))1.4142135623730951)((-(c0-(((fcrho)g)z)))/((epII1.4142135623730951)^2)))) Failed to evaluate expression. - Expression: dvol(-((mod.uz+mod.wx)((nT>nb)((((0.5((0.5((((2(((ep12^2)+(ep13^2))+(ep23^2)))+(ep11^2))+(ep22^2))+(ep33^2)))^(-0.5)))(0.5(2ep11)))1.4142135623730951)((-(c0-(((fcrho)g)z)))/((epII1.4142135623730951)^2)))))) Failed to evaluate Jacobian of expression. - Expression: dvol(-mod.spf.K_stress_tensorxz) Failed to evaluate Jacobian of expression. - Expression: ((mod.p-mod.spf.K_stress_tensorxx)test(mod.ux)-mod.spf.K_stress_tensorxytest(mod.uy)-mod.spf.K_stress_tensorxztest(mod.uz)-mod.spf.K_stress_tensoryxtest(mod.vx)+(mod.p-mod.spf.K_stress_tensoryy)test(mod.vy)-mod.spf.K_stress_tensoryztest(mod.vz)-mod.spf.K_stress_tensorzxtest(mod.wx)-mod.spf.K_stress_tensorzytest(mod.wy)+(mod.p-mod.spf.K_stress_tensorzz)test(mod.wz))*(dvol)
what can be the issue?
thank you, all the best, V.
Hi, I got this error when I try to run the model: Velocity u, Pressure p Attempt to evaluate negative power of zero. - Function: ^ Failed to evaluate temporary symbolic derivative variable. - Variable: epII@VDN$mod.ux - Defined as: (0.5*((0.5*((((2*(((ep12^2)+(ep13^2))+(ep23^2)))+(ep11^2))+(ep22^2))+(ep33^2)))^(-0.5)))*(0.5*(2*ep11)) Failed to evaluate temporary symbolic derivative variable. - Variable: nb@VDN$mod.ux - Defined as: (((0.5*((0.5*((((2*(((ep12^2)+(ep13^2))+(ep23^2)))+(ep11^2))+(ep22^2))+(ep33^2)))^(-0.5)))*(0.5*(2*ep11)))*1.4142135623730951)*((-(c0-(((fc*rho)*g)*z)))/((epII*1.4142135623730951)^2)) Failed to evaluate temporary symbolic derivative variable. - Variable: n@VDN$mod.ux - Defined as: (nT>nb)*((((0.5*((0.5*((((2*(((ep12^2)+(ep13^2))+(ep23^2)))+(ep11^2))+(ep22^2))+(ep33^2)))^(-0.5)))*(0.5*(2*ep11)))*1.4142135623730951)*((-(c0-(((fc*rho)*g)*z)))/((epII*1.4142135623730951)^2))) Failed to evaluate temporary symbolic derivative variable. - Variable: mod.spf.mu@VDN$mod.ux - Defined as: (nT>nb)*((((0.5*((0.5*((((2*(((ep12^2)+(ep13^2))+(ep23^2)))+(ep11^2))+(ep22^2))+(ep33^2)))^(-0.5)))*(0.5*(2*ep11)))*1.4142135623730951)*((-(c0-(((fc*rho)*g)*z)))/((epII*1.4142135623730951)^2))) Failed to evaluate temporary symbolic derivative variable. - Variable: mod.spf.mu_eff@VDN$mod.ux - Defined as: (nT>nb)*((((0.5*((0.5*((((2*(((ep12^2)+(ep13^2))+(ep23^2)))+(ep11^2))+(ep22^2))+(ep33^2)))^(-0.5)))*(0.5*(2*ep11)))*1.4142135623730951)*((-(c0-(((fc*rho)*g)*z)))/((epII*1.4142135623730951)^2))) Failed to evaluate temporary symbolic derivative variable. - Variable: mod.spf.K_stress_tensorxz@VDN$mod.ux - Defined as: (mod.uz+mod.wx)*((nT>nb)*((((0.5*((0.5*((((2*(((ep12^2)+(ep13^2))+(ep23^2)))+(ep11^2))+(ep22^2))+(ep33^2)))^(-0.5)))*(0.5*(2*ep11)))*1.4142135623730951)*((-(c0-(((fc*rho)*g)*z)))/((epII*1.4142135623730951)^2)))) Failed to evaluate expression. - Expression: dvol*(-((mod.uz+mod.wx)*((nT>nb)*((((0.5*((0.5*((((2*(((ep12^2)+(ep13^2))+(ep23^2)))+(ep11^2))+(ep22^2))+(ep33^2)))^(-0.5)))*(0.5*(2*ep11)))*1.4142135623730951)*((-(c0-(((fc*rho)*g)*z)))/((epII*1.4142135623730951)^2)))))) Failed to evaluate Jacobian of expression. - Expression: dvol*(-mod.spf.K_stress_tensorxz) Failed to evaluate Jacobian of expression. - Expression: ((mod.p-mod.spf.K_stress_tensorxx)*test(mod.ux)-mod.spf.K_stress_tensorxy*test(mod.uy)-mod.spf.K_stress_tensorxz*test(mod.uz)-mod.spf.K_stress_tensoryx*test(mod.vx)+(mod.p-mod.spf.K_stress_tensoryy)*test(mod.vy)-mod.spf.K_stress_tensoryz*test(mod.vz)-mod.spf.K_stress_tensorzx*test(mod.wx)-mod.spf.K_stress_tensorzy*test(mod.wy)+(mod.p-mod.spf.K_stress_tensorzz)*test(mod.wz))*(dvol) what can be the issue? thank you, all the best, V.
