rotate the ball sphere with angular velocity using rigid connector
Posted 7 janv. 2018, 22:49 UTC−5 0 Replies
Hi...
How to rotate the ball sphere structure with angular velocity and the same time this ball was applied the external force. This problem similar with the concept of lubrication. I want to study about lubrication which is consists ball and cup structure. The cup is fixed. The fluid is added between ball and cup. The ball must be applied the rotation with angular velocity and external force to analyse the effect of ball movement in lubrication. Can anyone help to solve this problem. Thank you.
Hello Syafiq Along
