Winding Direction in Coil Geometry
After drawing a chunck block, I set this block as a homogenized multi-turn coil with circular coil-type. Then I need to select edges with a consistent direction to make it work as the coil.
The only problem is, only one edge element shows opposite direction. Does anybody can fix this kind of problem?
1 Reply Last Post 17 janv. 2018, 11:59 UTC+1
Posted: 8 years ago 17 janv. 2018, 11:59 UTC+1
Since this is a closed-loop non-circular coil, you may want to change to "numeric coil" type, and specify the input using internal boundary orthogonal to the coil direction.
