Trying to simulate electrical arcing
As the title says, I'm trying to simulate electrical arcing using COMSOL. Specifically, I am trying to use COMSOL to determine whether or not arcing will occur in a high voltage battery configuration with various gasses surrounding the batteries. If anyone has any knowledge regarding this topic and knows which physics interfaces I would have to use and how to use those interfaces I would very much appreciate your help!
2 Replies Last Post 4 févr. 2018, 21:27 UTC+1
Posted: 8 years ago 3 févr. 2018, 06:07 UTC+1
Arcing detection is possible by using Plasma Module -> DC discharge. If the self-sustained dicharge is possible in the configuration you investigate then the arcing will take place also. For more information see https://www.comsol.com/story/seeking-out-electrical-arcing-regions-in-satellite-systems-56891
Arcing detection is possible by using Plasma Module -> DC discharge. If the self-sustained dicharge is possible in the configuration you investigate then the arcing will take place also. For more information see [https://www.comsol.com/story/seeking-out-electrical-arcing-regions-in-satellite-systems-56891](https://www.comsol.com/story/seeking-out-electrical-arcing-regions-in-satellite-systems-56891)
Posted: 8 years ago 4 févr. 2018, 21:27 UTC+1
Thank you very much!
