Is it possible to have a varying geometry?
Hi all,
I am looking at building a model which describe the distribution of potential (band bending) within a semiconductor.
The potential distribution is given in the following function
V = V0 * (1-(x/W))^ 2 at 0 < x < W
V = 0 at x >W
Where
W = Ld * ( 2* V0 * F / (R * T) ) ^ (1/2)
and Ld, F, R and T are all constants
V0 will be a variable which I would like to make a step change later in the model.
The problem is that when I try to define this in a piecewise function, it all work well if my V0 and W is defined as a parameter having a fix value. When I start to make V0 and W as a variable, my piecewise function does not work.
Any suggestion on how to solve this problem?
Thank you
Chin Kin
4 Replies Last Post 8 avr. 2011, 13:03 UTC+2
Posted: 1 decade ago 7 avr. 2011, 17:17 UTC+2
what about trying an analytical function of the type
y=x/W=x/sqrt(Ld*(2*V0*F/(R*T))
V(y) = V0*(1-y)^2*(y<1)
and restrain to y>=0
Hi what about trying an analytical function of the type y=x/W=x/sqrt(Ld*(2*V0*F/(R*T)) V(y) = V0*(1-y)^2*(y=0 -- Good luck Ivar
Posted: 1 decade ago 7 avr. 2011, 19:34 UTC+2
Thank you Ivar. It works, but not when I would like to implement a function to V0 under time dependant study.
The way I introduce the time dependant study is I let the function
V(y) = V0*step1(t)*(1-y)^2*(y<1)
where step1 is the step function which I am interested to look at in a time dependant model.
The error I obtained is undefined variable, t.
Is it not possible for comsol to recognise that t is part of the time dependant function?
Please help.
Chin Kin
Thank you Ivar. It works, but not when I would like to implement a function to V0 under time dependant study. The way I introduce the time dependant study is I let the function V(y) = V0*step1(t)*(1-y)^2*(y
Posted: 1 decade ago 8 avr. 2011, 06:57 UTC+2
normally yes, but I have noticed that if you do not have any transient study defined, or even loaded then "t" is often not recognised.
Workaround: define a "Parameter" as t = 0[s] then it normally works. As a Parameter is read once at execution of the solver it can be overwritten later by COMSOL without any errors
Hi normally yes, but I have noticed that if you do not have any transient study defined, or even loaded then "t" is often not recognised. Workaround: define a "Parameter" as t = 0[s] then it normally works. As a Parameter is read once at execution of the solver it can be overwritten later by COMSOL without any errors -- Good luck Ivar
Posted: 1 decade ago 8 avr. 2011, 13:03 UTC+2
Thanks. Problem solved.
Chin Kin
Thanks. Problem solved. Best regards, Chin Kin
