How to connect in Heat transfer?
Posted 17 nov. 2009, 00:09 UTC+1 3 Replies
Hello
I am working currently with “Comsol 3.5 a” and I try a heat process with the modules heat transfer to simulate. My process consists of 3 phases and each phase has different boundary conditions and hence different model. The main body is the same but the boundary conditions change every 7 seconds. I can only simulate separately each phase and would like to leave all phases converge, so the conditions at the end of the first phase as the initial conditions of the second phase and at the end of the second phase as the initial conditions of the third phase, and again from the beginning. In short, a cycle runs in 21 seconds and consists of three phases. Injection (7s) - Cooling (7s) - cast (7s).
My question is how I can connect the three phases. I would like to let the whole then run in several cycles. Thank you for any words of advice
Hervé
Hervé
3 Replies Last Post 6 janv. 2010, 20:03 UTC+1
