Temperature dependent thermal conductivity.
Hi.
In heat transfer module,
Do I have to choose the solver manually if I want to define the temperature dependent thermal conductivity k(T)??
, or the comsol solves it automatically??
Thank you for reading .
1 Reply Last Post 19 avr. 2011, 11:22 UTC+2
Posted: 1 decade ago 19 avr. 2011, 11:22 UTC+2
my advice, always use default settings as proposed by COMSOL first, then in case of doubt only, try others yourself ;)
If you look carefully most of the materials data in the COMSOL material DB are T or even T&p dependent
Hi my advice, always use default settings as proposed by COMSOL first, then in case of doubt only, try others yourself ;) If you look carefully most of the materials data in the COMSOL material DB are T or even T&p dependent -- Good luck Ivar
