Cannot Resolve Domain relations: Bizarre behavior
First let me just say I have read this post (www.comsol.com/community/forums/general/thread/13136/) covering this topic, my problem is different.
I have a simple geometry, a hexahedron that gets rotated about an axis to make some copies. If i define the hexahedron as a solid and do this, I get the error I stated in the subject line. However, If i define the hexahedron as a surface, then do my rotations and finally then convert to a solid, i can form the union.
Can anyone explain this behavior? I have attached my .mph file (Comsol 4.1).
Its easy to switch back and forth to observe this bizarreness. Just disable/enable the conversion and set the hexahedron to surface/solid to toggle back and forth and observe the error
Adam
3 Replies Last Post 19 avr. 2011, 18:14 UTC+2
Posted: 1 decade ago 19 avr. 2011, 17:18 UTC+2
I believe it is because you have not defined a sphere around for the air, When I add a sphere at the centre of radius 50 mm your physics become alive again ;)
By the way you should upgrade to the latest patch, see the main web site
Hi I believe it is because you have not defined a sphere around for the air, When I add a sphere at the centre of radius 50 mm your physics become alive again ;) By the way you should upgrade to the latest patch, see the main web site -- Good luck Ivar
Posted: 1 decade ago 19 avr. 2011, 18:11 UTC+2
I had a cylinder around the whole thing, and it still was giving the same error. I took it out so make the model simpler for people to try out. I have attached a model with a cylinder/sphere per your instructions around the whole thing and it still give the same error. hmmmm
Posted: 1 decade ago 19 avr. 2011, 18:14 UTC+2
well I added a sphere and it works OK but I have 4.1.0.185 !?
Hi well I added a sphere and it works OK but I have 4.1.0.185 !? -- Good luck Ivar
