Failed to find a solution. The relative residual (0.011) is greater than the relative tolerance.
Hi !
I am working on the Frequency domain, in the Thermoviscous acoustics and Pressure acoustics modules.
I get this error, only when I operate at lower frequencies ( eg. < 50Hz). I have used the same model for high frequencies and am certain that there is no issue with the physics or the boundary conditions( as suggested on other posts in this forum ).
Is increasing the relative tolerance the only possible solution to this?
Thank you in advance!
0 Replies Last Post 17 mars 2018, 23:32 UTC+1
Hello Nikhil Gerard
