capillary
Posted 23 mars 2018, 15:43 UTC−4 0 Replies
I'm looking for anything that could help me. My task is only to describe the capillaries, which are usually in a heat pipe. I found a tutorial that is not my case, even though "Capillary Filling - Phase Field Method" is called. I try to simulate a pipe with capillary on the walls. The pipe is vertical and the water is below. it is to expect that the water goes up by the capillary(porous media) on the walls and the low pressure by itself. I have seen all the tutorial in this regard. Nothing helped
Hello Osama Tabbakh
