Lars Gregersen
COMSOL Employee
7 years ago
12 avr. 2018, 11:52 UTC+2
I'm sure we can figure something out, but I don't understand what model you have.
Is your model a shell or a plate model? Is the geometry 2D or 3D? What is a shell dataset?
It may help if you could post a simplified version of the model.
Lars Gregersen
Comsol Denmark
Riccardo Roberto De Lucia
7 years ago
16 avr. 2018, 09:19 UTC+2
Hi Lars,
thank you for your reply. I'm using a Shell model to represent a simple thin aluminium rectangular plate. As far as I understand, plate models are used to model objects which are similar to membranes or very thin layers of material over planar surfaces. Moreover, I will need to extend this model to orthotropic curved surfaces (in particular I will need to investigate violin top plates eigenmodes). My geometry is a 2D object. I refer to shell dataset as the set of 3D data coming from the study, which is collected under Results -> Data Sets -> Shell 1. You can find a simplified version of the project attached to this reply. Thank you!
Hi Lars,
Lars Gregersen
COMSOL Employee
7 years ago
18 avr. 2018, 10:58 UTC+2
Thank you for the clarification.
Currently there are no way to extract the data you need using mpheval or mphinterp. We are looking into ways to support that in the near future.
If you can create a plot of the data you need, you can use:
pd = mphplot(model, 'pg1')
and then extract the data from the pd-struct that is returned from mphplot. Note that data that are used for plotting are 32-bit floats even though the computations are carried out as 64-bit doubles.
Lars Gregersen
Comsol Denmark
7 years ago
23 avr. 2018, 08:54 UTC+2
Hi Lars,
thank you again for being helping me, and sorry my late reply. I will surely give it a try! Currently, I find that the most efficient method to obtain data for postprocessing outside Comsol is through the Export options, by the usage of csv files, which I use to import data into MatLab. Hope to see some updates in the future!
All the best,
Riccardo
Hi Lars,
All the best,
Riccardo
