Transient heat transfer in fluid issue
Hi everyone,
I'm now modeling a simple case that a 2d laminar flow with temperature T1 goes through a pipe (T2, and T1 > T2) with a constant velocity. I'm studying the transient state. What seems not physical is that in the temperature results profile, if initial T1 is higher enough > 500K, a little bump will appear in the first couples (0-40s) of seconds, and smooths out when it approches to the steady state (50-100s). I had tried two initial boundery conditions for fluid (temperature or inflow), both showed the weired behavior. (as shown in figure below) I'm curious about where these "bumps" come from? Cause I didn't add any external heat source into the system. The mph file is attached as well. Does anyone have an idea?
https://image.ibb.co/my9pjH/Comsol_temp_0_100s_line.png
THANK YOU IN ADVANCE!!!
Xiaoyu
2 Replies Last Post 1 mai 2018, 14:59 UTC+2
Sven Friedel COMSOL Employee
Posted: 7 years ago 30 avr. 2018, 15:56 UTC+2
Dear Xiaoyu see: https://www.comsol.ch/support/knowledgebase/1172/ Regards, Sven
Posted: 7 years ago 1 mai 2018, 14:59 UTC+2
Thank you so much!!! Sven. It works perfectly.
Xiaoyu
>Dear Xiaoyu >see: https://www.comsol.ch/support/knowledgebase/1172/ >Regards, >Sven Thank you so much!!! Sven. It works perfectly. Xiaoyu
