Extrude with different values
Hello all,
I want to extrude a curve with different values. I mean I want to make some parts of the curve thicker and some parts thinner. How can I do it with extrude operator? I've attached 2 pictures. Could you please help me.
Kind regards
4 Replies Last Post 8 mai 2018, 13:51 UTC+2
Posted: 7 years ago 2 mai 2018, 19:39 UTC+2
You could try to extrude a curve based on the thickness profile from perpendicular plane and then apply partition, delete or logical operations.
Cheers Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
You could try to extrude a curve based on the thickness profile from perpendicular plane and then apply partition, delete or logical operations. Cheers Edgar
Posted: 7 years ago 2 mai 2018, 20:01 UTC+2
Dear Edgar,
Could you please explain more?
Kind regards
Dear Edgar, Could you please explain more? Kind regards
Posted: 7 years ago 6 mai 2018, 12:49 UTC+2
Hello Shaghayegh, you can import such a spline from a 3d-CAD-Programm. It's easy to build a spline with the loft-function (see attached example).
Kind regards Benno from Munich
Hello Shaghayegh, you can import such a spline from a 3d-CAD-Programm. It's easy to build a spline with the loft-function (see attached example). Kind regards Benno from Munich
Posted: 7 years ago 8 mai 2018, 13:51 UTC+2
Hi Benno,
Great! thanks a lot.
Best regards, Shaghayegh
Hi Benno, Great! thanks a lot. Best regards, Shaghayegh
