boundary condition
Hi all,
in 2D stationary PDE
if i put the initial value of u=10 (for example) at certain boundary.
After solution
when calculate u at this boundary I don't find it 10 but a value near it?
Regards
1 Reply Last Post 4 mai 2011, 15:46 UTC+2
Posted: 1 decade ago 4 mai 2011, 15:46 UTC+2
You are applying the boundary condition normal to the boundary ( 1D) and comsol showing you the calculated boundary, i.e., check the normal value to your boundary, you will find the applied value.
Hi You are applying the boundary condition normal to the boundary ( 1D) and comsol showing you the calculated boundary, i.e., check the normal value to your boundary, you will find the applied value.
