2D Cross Section and Parametric Sweep
Dear all
I am simulating a Cross section of a 3D problem. Everything goes well, except when I want to sweep a geometrical parameter (with the Parametric Sweep, not Auxiliary of course.)
If I do it, it does not reconstruct the 3D object and then takes the linecut. All I have is a warning: "3D objects preceding work plane need rebuild." That is strange as I am pretty sure it worked in the past (5.3)
Is there is a way to force the 5.3a version to update the 3D before taking the Cross Section ?
This is a severe limitation to Cross section...
PS: It works by sweeping a material parameter, so the parametric sweep is working
2 Replies Last Post 24 mai 2018, 16:47 UTC+2
Daniel Bertilsson COMSOL Employee
Posted: 7 years ago 24 mai 2018, 15:56 UTC+2
Dear Jean,
This kind of modelling works only under certain conditions. Please send your model to COMSOL support, and we will help you.
Best regards, Daniel Bertilsson COMSOL AB
Dear Jean, This kind of modelling works only under certain conditions. Please send your model to COMSOL support, and we will help you. Best regards, Daniel Bertilsson COMSOL AB
Posted: 7 years ago 24 mai 2018, 16:47 UTC+2
Updated: 7 years ago 24 mai 2018, 16:47 UTC+2
Dear Daniel,
Thanks a lot for your answer. Fortunately, I solved my problem by : 1: rebooting the computer 2 :re-installing Comsol 5.3a
Don't ask me how, it fxed it, but it worked.
Best regards, Jean
Dear Daniel, Thanks a lot for your answer. Fortunately, I solved my problem by : 1: rebooting the computer 2 :re-installing Comsol 5.3a Don't ask me how, it fxed it, but it worked. Best regards, Jean
