heat transfer
Posted 23 nov. 2009, 05:32 UTC−5 1 Reply
I have a angle wall only in concrete (thermal conductivity=2), one meter for each side of this wall. The interior temperature in 20°C and the exterior is 0°C. The interior transfer coefficient is h=7.69 and the exterior tranfer coefficient is h=25. The other boundaries are thermal insulation boundaries.
I have not the same heat flux between the interior and the exterior boundaries. Why??!!
And the two heat flux values are also changing with the meshing (the flux on the interior boundary is changing more sensibly than the "exterior flux"), Why??
Whereas I tested the same wall but in plan configuration (one meter of this plan wall) and I have the same flux between these boundaries (no variation with different meshing). So , in the last configuration, it is good.
Thanks for helping me on it.
1 Reply Last Post 23 nov. 2009, 08:40 UTC−5
