Error messages
Posted 11 mai 2011, 00:43 UTC+2 Version 4.0a 3 Replies
I'm doing some simulations to compute the magnetic forces
between two magnets. I'm using the parametric sweep mode
as some dimensions of the magnets are parameters.
However, I often have error messages and I don't know why:
* Error in sweep: The following feature has encountered a problem:
- Feature: Compile Equations: Stationary (sol1/st1)
- Error: Internal error in geometry decomposition
* Error in automatic sequence generation:
* Java heap space error
For example, I'm varying a parameter between 0 and 10 with a step
of 1 and the simulation for the step 3 doesn't work but all the others
work.
Attached you will find the comsol file used (as it is a symmetrical situation, it is
divided along the plan y0z). There are two parametric sweeps
which are enabled for the variables e (between 0 and 10) and delta_l (between 0 and 0.0065).
When I run the simulations, I get an error message and not all the results.
I'm obliged to do other simulations to get the missing results.
If someone could help me in any way whatsoever, I'd be very grateful!!
Jimmy
work.
Jimmy
3 Replies Last Post 27 juil. 2011, 11:38 UTC+2
