time dependent study, external current density in mf model.
I am using COMSOL version 4.2, module AC/DC, Magnetic Fields (mf) model, 2D axisymmetric wizard and time dependent study.
I have created in "Global Definitions" a function of type "Sawtooth" named by "F1saw".
As " External Current Density" I want to use "Jc*F1saw(t)" but the program says that it is "unexpected unit of input", where "Jc" is given as a parameter and is units are "A/m^2".
I really don't know what I am doing wrongly.
Could you help me?
Thanks in advance.
Isa
9 Replies Last Post 27 mai 2011, 10:56 UTC+2
Posted: 1 decade ago 25 mai 2011, 14:15 UTC+2
Isa,
did you assign a unit to your Sawtooth function? It should be unitless for your application.
Cheers
Edgar
Isa, did you assign a unit to your Sawtooth function? It should be unitless for your application. Cheers Edgar
Posted: 1 decade ago 25 mai 2011, 14:41 UTC+2
thank-you Edgar.
No, I define it simply. But when I plot it, as title appears "F1Saw(t)", so it seems that by default it takes the variable time, doesn't it?
How should I do it?
Thanks again in advance.
Isa
Hello, thank-you Edgar. No, I define it simply. But when I plot it, as title appears "F1Saw(t)", so it seems that by default it takes the variable time, doesn't it? How should I do it? Thanks again in advance. Best regards, Isa
Posted: 1 decade ago 26 mai 2011, 16:43 UTC+2
Sorry I still didn't received Comsol 4.2 but with 4.1 I set up a model with a triangle function multiplied by Jc.
Posted: 1 decade ago 26 mai 2011, 17:55 UTC+2
Dear Loic,
Thank-you very much for your help!
I have opened your file in both, comsol 4.1 and 4.2, and yes, you are right, it allows me to introduce the external current density as "Jc*tria1(t)" but you can see that it put itself in orange colour (in both versions), which points out that it is "unexpectd unit of input"... It is like a warning, not an error because later the program runs.
I think it is because tria1(t) has units of "seconds", do you know if we can do it unitless?
Thanks in advance!
Isa
Dear Loic, Thank-you very much for your help! I have opened your file in both, comsol 4.1 and 4.2, and yes, you are right, it allows me to introduce the external current density as "Jc*tria1(t)" but you can see that it put itself in orange colour (in both versions), which points out that it is "unexpectd unit of input"... It is like a warning, not an error because later the program runs. I think it is because tria1(t) has units of "seconds", do you know if we can do it unitless? Thanks in advance! Best regards, Isa
Posted: 1 decade ago 27 mai 2011, 06:07 UTC+2
I don't know if it is possible to do it unitless but as you said, it is a warning not an error. Comsol is just saying that he cannot determine it automatically.
Posted: 1 decade ago 27 mai 2011, 08:50 UTC+2
Ok. Understood.
Again, thank-you!
Isa
Ok. Understood. Again, thank-you! Best regards, Isa
Posted: 1 decade ago 27 mai 2011, 08:59 UTC+2
Isa,
you might consider to define a constant with an appropriate unit, assign the value 1 and multiply with your function to remove the unit issue.
Cheers Edgar
Isa, you might consider to define a constant with an appropriate unit, assign the value 1 and multiply with your function to remove the unit issue. Cheers Edgar
Sven Friedel COMSOL Employee
Posted: 1 decade ago 27 mai 2011, 10:17 UTC+2
the correct way calling a time function *without orange* marks is:
sawtooth(t[1/s])[A/m^2]
The [1/s] removes the unit [s] and creates a unitless input for the function call.
The [A/m^2] adds the correct unit required for the entry field.
Sven
Hi, the correct way calling a time function *without orange* marks is: sawtooth(t[1/s])[A/m^2] The [1/s] removes the unit [s] and creates a unitless input for the function call. The [A/m^2] adds the correct unit required for the entry field. Sven
Posted: 1 decade ago 27 mai 2011, 10:56 UTC+2
Dear Sven,
I have tried your suggestion and, obviously (it makes sense), it has worked!
Thank-you very much!
Isa
Dear Sven, I have tried your suggestion and, obviously (it makes sense), it has worked! Thank-you very much! Best regards, Isa
