Using sign and abs on variables
I typed the following into a boundary condition:
-sign(solid.u_tX)*beta*(abs(solid.u_tX))^m
where beta and m are constants that I defined, and solid.u_tX is the x-velocity. However, when I tried to solve, COMSOL could ot find consistent initial values. If I remove the sign and abs functions (and set m = 1), then COMSOL will solve. Is there a way to get this to work with the sign and abs functions?
Henry
1 Reply Last Post 1 juin 2011, 06:46 UTC+2
Posted: 1 decade ago 1 juin 2011, 06:46 UTC+2
sign and abs functions are know to have discontinuities, perhaps if you check that you work inone 1 quadrant, or that you smoothen the transitions it would solve better
Hi sign and abs functions are know to have discontinuities, perhaps if you check that you work inone 1 quadrant, or that you smoothen the transitions it would solve better -- Good luck Ivar
