Linking transient pulse to heating generated
Hey guys,
I am trying to model a transient EM pulse (E_max*exp(-t-t0)^2) traveling through a non-dispersive media which generates microwave heating.
I am wondering if someone could recommend the best physics/study type for this model.
Right now I am trying to implement it using Transient Electromagnetic Waves physics, and defining the source under scattering boundary conditions. This generates the required pulse.
Now linking the heat is giving me a problem--should I use microwave heating physics?
Any help or examples are greatly appreciated. (the built in modules are all frequency studies, not time dependent).
-John, LA Tech
2 Replies Last Post 13 juin 2011, 15:44 UTC+2
Posted: 1 decade ago 10 juin 2011, 20:33 UTC+2
Here is a copy of the model.
If you turn off under solver settings ->dependent variables->temperature-> solve for this field; the pulse will be computed. But when I try to solve for the T field, it gives me errors. Just looking at the pulse, you can view the Total Power Dissipation Density, which should be the data COMSOL needs to solve for the T field.
I guess I am missing some boundary condition?
Any help is appreciated,
John
Here is a copy of the model. If you turn off under solver settings ->dependent variables->temperature-> solve for this field; the pulse will be computed. But when I try to solve for the T field, it gives me errors. Just looking at the pulse, you can view the Total Power Dissipation Density, which should be the data COMSOL needs to solve for the T field. I guess I am missing some boundary condition? Any help is appreciated, John
Posted: 1 decade ago 13 juin 2011, 15:44 UTC+2
I have tried a few more things, but with no luck.
Any advice or suggestions are appreciated,
John
I have tried a few more things, but with no luck. Any advice or suggestions are appreciated, John
