PDMS properties?
I am currently working on a Solid-Acoustic problem, where I would like to use the material PDMS (polydimethylsiloxane) in two regions. However, when I try to make a user defined material, by inserting the density (965 kg/m3), Poisson's Ratio (0.5) and Young's Modulus (0,98 MPa), I cannot solve the problem. If I however choose another solid it solves it in no time.
Do any of you know, if a PDMS material has been made and can be imported? Or do you know which material constant I need?
Regards
Kasper
1 Reply Last Post 14 juin 2011, 22:25 UTC+2
Posted: 1 decade ago 14 juin 2011, 22:25 UTC+2
try poisson 00.495.
AS 0.5 is REALLY too much ;),
but normally you ave better material models for large nu materials, take a look at the doc
Hi try poisson 00.495. AS 0.5 is REALLY too much ;), but normally you ave better material models for large nu materials, take a look at the doc -- Good luck Ivar
