mean curvature in comsol 4.2
Hi!
For a moving-mesh problem I am trying to get the value of the mean curvature of a surface. 'r', like in Comsol 4.1 doesn't seem to work anymore since it says 'unknown variable'.
Can anyone help me?
Christian
3 Replies Last Post 27 juil. 2012, 13:10 UTC+2
Posted: 1 decade ago 20 juin 2011, 17:30 UTC+2
As a suggestion:
Is there a way to compute the gradient of the normal vector of the surface?
I am unable to find anything in the documentation apart from the formulas I already know.
Christian
As a suggestion: Is there a way to compute the gradient of the normal vector of the surface? I am unable to find anything in the documentation apart from the formulas I already know. Best regards, Christian
Posted: 1 decade ago 21 juin 2011, 16:50 UTC+2
Ok, next idea:
I discovered, that there is a differential function d(f,x) where f is the derived function and x the derivation direction. I tried to get the gradient of the normal vector as
grad(n) = d(nx,x) + d(ny,y) + d(nz,z)
but this produces zero for me. Am I using the wrong normal vector?
Ok, next idea: I discovered, that there is a differential function d(f,x) where f is the derived function and x the derivation direction. I tried to get the gradient of the normal vector as grad(n) = d(nx,x) + d(ny,y) + d(nz,z) but this produces zero for me. Am I using the wrong normal vector?
Posted: 1 decade ago 27 juil. 2012, 13:10 UTC+2
You have find the answer for your problem? I've the same. It produces 0 for me too.
You tried weak contribution with divergence theorem? For that the is to calculate the [ ] terms. You see what I mean?
Hello, You have find the answer for your problem? I've the same. It produces 0 for me too. You tried weak contribution with divergence theorem? For that the is to calculate the [ ] terms. You see what I mean?
