What is "Layer" in V4.1 and V4.2
I could not find what the definition and function of Layers option are in V4.1 and V4.2.
Can whoever knows about it drop a line please?
The only thing that I found in the user guide and was not useful for me is:
Layers
Layers can be used to create sandwich primitives. Specify the thicknesses of layers in the Layers table, and optionally a name for each layer. The outermost layer comes first. Select the check boxes to specify where to apply the layers.
JW
3 Replies Last Post 3 juil. 2015, 20:58 UTC+2
Posted: 1 decade ago 22 juin 2011, 02:40 UTC+2
Basically layers allow you to create several concentric spheres, cubes, etc in a single step. Try it out, you'll see what I mean.
Posted: 1 decade ago 29 juil. 2011, 20:44 UTC+2
Thanks Jean-Francois
Posted: 1 decade ago 3 juil. 2015, 20:58 UTC+2
How can layers be used to divide cylinders with varying angles, from trying your you explanation concentric cylinders are possible but divided by 90 degrees
[QUOTE] Basically layers allow you to create several concentric spheres, cubes, etc in a single step. Try it out, you'll see what I mean. [/QUOTE] How can layers be used to divide cylinders with varying angles, from trying your you explanation concentric cylinders are possible but divided by 90 degrees
