Extruding to 3d
2 questions:
1) I am creating a ring in 2d, and it seems perfectly circular, but when I extrude it to 3d, it suddenly gets slightly jagged sides and becomes a sort of polygon. I tried to fillet it in 2d and then extrude, but it makes no difference, the 3d still has edges. Anyone know how to fix this?
2) Is there any way to put a 2d face on a 3d object? For example, on a cylinder, I would like to put a small circle on its top face to model a laser's heat deposition. I think this would let me impose heat transfer conditions on the boundary. Other suggestions are also welcome.
5 Replies Last Post 16 mai 2012, 19:15 UTC+2
Hello Dhruv Kedar
Posted: 1 decade ago 16 mai 2012, 17:20 UTC+2
I have the same problem that your first question. Did you find a way to get out of it?
Hi, I have the same problem that your first question. Did you find a way to get out of it?
Posted: 1 decade ago 16 mai 2012, 18:29 UTC+2
I can't remember since it was a while ago, but I think I ended up cutting out the only part of the 3d extrusion that I only needed the physics for.. This made it circular.
Posted: 1 decade ago 16 mai 2012, 18:44 UTC+2
check you graqphics rendering, you can get a polygone by the way your cylinder is represented in the GUI graphics view even if it is "perfect" in shape. I'm no longer sure where that option is on 3.5, there should be an old thread about that too
Hi check you graqphics rendering, you can get a polygone by the way your cylinder is represented in the GUI graphics view even if it is "perfect" in shape. I'm no longer sure where that option is on 3.5, there should be an old thread about that too -- Good luck Ivar
Posted: 1 decade ago 16 mai 2012, 19:13 UTC+2
Thank you for your help. But I dont think it is a question of graphic representation because COMSOL considers that there are 4 boundaries and not just one, as for a cylinder.
Posted: 1 decade ago 16 mai 2012, 19:15 UTC+2
then check your relative and absolute tolerances of the graphics, again forgotten where they are in 3.5, but I believe there were 2 variables to tweak, particularly if you have "small" items with "large" (m) scale
Hi then check your relative and absolute tolerances of the graphics, again forgotten where they are in 3.5, but I believe there were 2 variables to tweak, particularly if you have "small" items with "large" (m) scale -- Good luck Ivar
