Error with Air as a medium material in calculating electrostatic force
Posted 7 juil. 2011, 02:50 UTC−4 Studies & Solvers Version 4.0a 8 Replies
I want to calculate the electrostatic force due to parallel plate capacitor, and the medium is air, so i make to plates and make a large Box and set its material >> Air
Now i use three physics: Electrostatic - Solid Mechanics - Moving Mesh.
But i usually have this error, and i want help in solving it.
Segregated group X1
Failed to evaluate variable.
- Variable: mat.epsilonr22
- Geometry: 1
- Domain: 6
- Variable: mod1.es.epsilonryy
- Defined as: mat.epsilonr22
- Variable: mod1.es.Dy
- Defined as: (mod1.es.Ey*(epsilon0_const*mod1.es.epsilonryy))
- Expression: d((-mod1.es.Dx*test(mod1.Vx)-mod1.es.Dy*test(mod1.Vy)-mod1.es.Dz*test(mod1.Vz))*(dvol_spatial),{test@1})
the model is attached, Thanks.
there is no model....
Sorry
Sorry
The first error you are getting is
"Segregated group X1
- Geometry: 1
- Domain: 6"
I looked at your materials and domain 6 has no selection. I am not sure what you are doing with your simulation but what you need to do is add a material to domain 6. What I did was to add it to the poly-si material and that error went away. In re-running the simulation again, I got this error as a new one:
"Segregated group 2
- Variable: mod1.es.nTz_Fes
- Geometry: 1
- Boundary: 20
- Expression: d((mod1.es.nTx_Fes*test(mod1.u)+mod1.es.nTy_Fes*test(mod1.v)+mod1.es.nTz_Fes*test(mod1.w))*(dvol),{test@2})"
This would seem to imply a boundary condition is not set right in your model. Not sure how to correct it since I am not all that familiar with your model.
Sometimes errors are real easy to spot just because I have done them on my own. When I see a "mat.epsilon" based error, I know that some domain/BC does not have a material assigned or has an empty value associated with it. BC errors can be a bit more difficult to solve as getting the physics right can be tricky.
Sorry
- Geometry: 1
- Domain: 6"
"Segregated group 2
- Geometry: 1
- Boundary: 20
Hi, Thank you very much.
I'll try to solve the material error now, and for the Force error i'll try and tell you the result
Again, Thank you very much, Mohamed.
Segregated group X2
- Variable: mod1.es.nTx_Fes
- Geometry: 1
- Boundary: 23
- Expression: d((mod1.es.nTx_Fes*test(mod1.u)+mod1.es.nTy_Fes*test(mod1.v)+mod1.es.nTz_Fes*test(mod1.w))*(dvol),{test@1})
so if any one understant this error tell me, Great thanks,
Mohamed.
the model is attached after solving the first error.
I tried to solve the second error but i can't
Segregated group X2
- Geometry: 1
- Boundary: 23
Mohamed.
I took a more detailed look at this and I think it is yelling at you because it doesn't know what the "es.nTx_Fes" function is. There looks to be nothing in your parameters or variables to tell comsol what it is. Boundary 23 is called out in the "boundary load 1" under solid mechanics and you just have this as a user defined option. While that is fine to do, I just don't see where you told comsol more info about this function. Maybe your syntax is wrong?
Thank you very much, the problem is solved.
Suggested Content
- BLOG Improving the Power of Optical Systems via Component Design
- FORUM Flow of water droplet in dielectric medium due to electrostatic force
- KNOWLEDGE BASE Warning: New Constraint Force Nodes Detected
- KNOWLEDGE BASE What to do when a linear stationary model is not solving
- FORUM Calculating Electrostatic Force without MEMS Module
