                                2 decades ago
                                14 déc. 2009, 05:48 UTC−5
                                                    Hello
I am not sure  I remember it well.
However I think that there was a first array where there were three columns. The first & second column corresponded   to  (x, y) coordinates of the vertices of the triangles/squares present in your solved geometry. Then the third column corresponds to the simulated magnitude (e.g. temperature at that point).
The rest of arrays should be related to the linear relations between the previous points. But I am not sure.
Cheers.
AP
                            Hello
Cheers.
AP
                                2 decades ago
                                                    Hello
Cheers.
AP
                            Hello
Cheers.
AP
                                2 decades ago
                                4 févr. 2010, 14:57 UTC−5
                                                    Hey,
Please did you resolv your problem? I have a same problem with the mphtxt format.
Thanks.
                            Hey,
Thanks.
                                2 decades ago
                                4 févr. 2010, 17:31 UTC−5
                                                    Hi Linda,
I was finally able to write out a mesh file in mphtxt format. Try understanding the format by exporting a very simple mesh (say that of a unit square) in mphtxt format from COMSOL and deciphering that.
Also, for help you can look up 'femmesh' command in the Commands Reference. Besides, the examples for meshes in multiphysics files (provided in the documentation) are also helpful.
Best of luck!
Saswati
                            Hi Linda,
Best of luck!
Saswati
                                2 decades ago
                                13 avr. 2010, 23:27 UTC−4
                                                    Thanks you Saswati.
Linda.
                            Thanks you Saswati.
Linda.
