Filename contains temporary path?
Posted 20 juil. 2011, 11:22 UTC−4 Version 4.2 0 Replies
recently I upgradet to version 4.2.
Using the same, completely unchanged Matlab scripts to run my models, that were running fine in version 4.1 causes a small problem.
I set the model path with: model.modelPath() and will try if using ModelUtil.path(path) will make a difference.
Anyways, I run the Comsol model from a local linux machine but the script connects to a remote Windows server.
When the model is done, some export files are written to the local linux machine like this for example:
model.result.export('data3').set('filename', ['v2_transient_param', num2str(p*sweep_step), '.dat']);
This used to work fine!
Files had the correct name and were stored at the correct location using version 4.1.
However, using v 4.2 the filenames contain a strange temporary path of the Windows Comsol server machine:
The file has this NAME, its not a path, its the filename itself:
"C:\Users\modeler\AppData\Local\Temp\cs09359\v2_transient_param0.83333.dat"
So the Windows path is part of the filename on the linux machine. At least the file is stored in the right directory.
But the strange path string in the beginning of the file name is confusing and makes automated postprocessing very difficult..
Did anyone experience the same and found a solution to it?
Thanks a lot and best regards,
Juergen
Hello Juergen Hansmann
