Transport of diluted species coupling with a previous study
Posted 21 nov. 2018, 19:18 UTC+1 Fluid & Heat, Computational Fluid Dynamics (CFD), Chemical Reaction Engineering Version 5.3a 1 Reply
Hello everyone,
I'm having some trouble coupling two different transport of diluted species studies. The process is like this:
First: In study 2 Time dependent, I run TDE for one specific hour (tds1-hour1) coupled with a turbulent flow (Study 1: Stationary) and I got a solution. In Study 2 I set as "Values of variables not solved for: Study 1: Stationary". Is this process correct?
Second: In study 3 Time depedent, I want to run another TDE for another specific hour (tds2-hour2) setting as initial value the solution of the previos TDE (tds1-hour1), coupled with the same turbulent flow. I've tried to set as "Initial values of variables solved for: Study 2 Time dependent" and "Values of variables not solved for: Study 1 Stationary" , but the results I get does not show the initial values of TDE (tds1-hour1) in minut 0. Can anyone please tell me how to fix this.
Thanks to all.
Esteban
