Henrik Sönnerlind
COMSOL Employee
7 years ago
26 nov. 2018, 11:04 UTC+1
Updated:
7 years ago
26 nov. 2018, 11:06 UTC+1
Avoid high refinement values in plot Quality settings. If values are supposed to be close to zero, you will just get an amplification of small numerical errors.
For thermal stress problems in particular, this will give very strong effects, unless the shape functions for the temperature is one order lower than for the displacements. The reason is that the stress is proportional to the difference between thermal strains (proportional to temperature) and mechanical strains (proportional to derivatives of displacements).
Henrik
Henrik Sönnerlind
COMSOL
Henrik
7 years ago
26 nov. 2018, 21:11 UTC+1
Updated:
6 years ago
22 janv. 2019, 03:25 UTC+1
Hi Henrik,
Thank for your kind replies very much! Ok, I know the oscillating values could be from numerical values. When I choose the "Quality"/"no refinement", the profile looks some smooth but looks like a step-wise curve. Please see the attached figures.
Xi
Hi Henrik,
Xi
Henrik Sönnerlind
COMSOL Employee
7 years ago
29 nov. 2018, 16:07 UTC+1
Hi Xi,
The stationary plot is just numerical noise (the stress is less than a microPascal).
The step-wise behavior is caused by using a cut line. A line in the geometry will have access to more information, so that proper inter-element averaging can be performed.
As for "shape functions of temperature", I mean the approximation of the temperature field within each element. You can change the order of the shape functions in the Discretization section in the settings for a physics interface. If you add a Thermal Stress multiphysics interface, the shape function order for the temperatures is lowered to Linear by default. When combine your physics interfaces manually, you will typically get Quadratic.
Note that the Y-direction stress due to thermal expansion will be small. The important stresses will occur in the horizontal direction. Which stress measure to use for studying damage will depend in the type of material you are dealing with.
Henrik
Henrik Sönnerlind
COMSOL
Hi Xi,
Henrik
7 years ago
30 nov. 2018, 18:04 UTC+1
Updated:
6 years ago
22 janv. 2019, 03:24 UTC+1
Hi Henrik,
Many thanks! I can understand that is numerical noise in the stationary case where the Y-stress should be zero. At this moment, I'm more interested in the vertical stress status. If needed, we can constraint the top boundary.
Xi
Hi Henrik,
Xi
Henrik Sönnerlind
COMSOL Employee
7 years ago
6 déc. 2018, 10:17 UTC+1
Hi Xi,
Inter element averaging works better if you have a line in the geometry, rather than a cut line.
Yes, a homogeneous external strain will just move the material, but not cause any stress (as long as the material is free to expand).
Henrik
Henrik Sönnerlind
COMSOL
Hi Xi,
Henrik
7 years ago
6 déc. 2018, 16:05 UTC+1
Updated:
6 years ago
Hi Henrik,
Thanks very much for your kind replies.
Xi
Hi Henrik,
Xi
