Three phase stator in Comsol 4.1
Hello everyone
I am trying to model a three phase stator ring of an induction motor without the rotor in order to solve and visualize the rotating magnetic field set up through three phase power.
My main question is how to make the currents on my multiturn coil domains three phases. I know a phasor needs to be used but where do I insert that information? In the current box of the multiturn coil domains by using 1 *e^wt?
Then the follow up question I have is, in my model so far, do I have the domains of the multiturn coils correct where both "coils" on opposite sides of the stator gets added to one multiturn coil domain?
Then will my model show the flux magnetitude by color and the flux lines produced by the three phase current if I use a time dependent study?
For help I have looked at the generator 2d model for Comsol 3.5a but I do not want to model the rotor and in my model the magnetic field is produced by the three phase current not the rotation of the rotor, thus a "motor".
And if I need to use the rotational machinery physics instead of magnetic field physics, what domain would rotate? The air domain inside the stator, the stator, the domain of the system, etc..?
Thank for your help.
Stephen Doty
5 Replies Last Post 6 oct. 2011, 14:08 UTC+2
Posted: 1 decade ago 6 sept. 2011, 15:59 UTC+2
Bump..........
I would really love some help.
Thanks.
Stephen Doty
Bump.......... I would really love some help. Thanks. Stephen Doty
Posted: 1 decade ago 6 sept. 2011, 16:00 UTC+2
Oh and I have upgraded to 4.2
Posted: 1 decade ago 7 sept. 2011, 08:57 UTC+2
Hi!
To visualize a rotating magnetic field you can play with the model I have changed.
I have added some parameters for current and phase shift...
The phasor can be used with frequency domain study as shown. In the player you have to switch to "dynamic data extension", if you want to produce an animated image.
Ralf
Hi! To visualize a rotating magnetic field you can play with the model I have changed. I have added some parameters for current and phase shift... The phasor can be used with frequency domain study as shown. In the player you have to switch to "dynamic data extension", if you want to produce an animated image. Ralf
Posted: 1 decade ago 8 sept. 2011, 11:18 UTC+2
Ralf
Thank you so much for helping me!!!!
I now understand how and where to put the phasor representation of the current for each of the multiturn coil domains. THANK YOU!!! I have been working at that forever..
Now when I change the material of the coil domains to iron without losses instead of the material being just air I get an error that it cannot evaluate a negative power of zero. Why??
How can I make the core of the coil domains iron instead of just air???
Thank you so so much for your help. I greatly appreciate it.
Stephen Doty
Ralf Thank you so much for helping me!!!! I now understand how and where to put the phasor representation of the current for each of the multiturn coil domains. THANK YOU!!! I have been working at that forever.. Now when I change the material of the coil domains to iron without losses instead of the material being just air I get an error that it cannot evaluate a negative power of zero. Why?? How can I make the core of the coil domains iron instead of just air??? Thank you so so much for your help. I greatly appreciate it. Stephen Doty
Posted: 1 decade ago 6 oct. 2011, 14:08 UTC+2
Hi!
Sounds like this one:
www.comsol.com/community/forums/acdc-module/thread/21990/
Ralf
Hi! Sounds like this one: http://www.comsol.com/community/forums/acdc-module/thread/21990/ Ralf
