"Complex numbers not supported" Error
Hi, I'm currently running COMSOL 4.0 with the AC/DC module attempting to create a finite element model of human tissue when passing a current through it. There are a bunch of tissues I've set up with electrical properties, and electrodes to both inject and sense current. I think I have everything set up correctly. However, when I run a frequency domain study, I get an error every time saying "Complex numbers not supported by Algebraic multigrid. Segregated group." I do not have any complex numbers being input into my model, and so can only assume that somewhere there's a square root of a negative number etc etc... Can anyone describe what that error code might mean? Or what might need to be modified abou the model to prevent it? I would attach the model here, but it appears to be too big to upload (20 MB).
Thanks very much,
Tyler
1 Reply Last Post 18 août 2011, 07:44 UTC+2
Posted: 1 decade ago 18 août 2011, 07:44 UTC+2
these kind of errors are often difficult to identify ;) Anyhow, I would suggest that you get hand on the latest version and tra again, with a fresh rebuild model in the latest version, as the v4 were not yet fully "ironed out"
Hi these kind of errors are often difficult to identify ;) Anyhow, I would suggest that you get hand on the latest version and tra again, with a fresh rebuild model in the latest version, as the v4 were not yet fully "ironed out" -- Good luck Ivar
