problem with parameter sweep (Comsol4.2)..‏
Hi all,
I have a wierd problem with paramteric sweep. I have a linear elastic, structural mechanics , stationary problem and I want to vary the young's modulus to see the effects.
When I put the more than 2 values in the parametric sweep, Comsol gives me an error, saying:
Failed to find a solution for all parameters,
even when using the minimum parameter step.
No convergence, even when using the minimum damping factor.
However, the wierd part is when I ran the values separately, manually on Comsol, OR when I put <= 2 values in the parametric sweep, it gives nice converging solutions...
Any ideas?
Thanks in advance
Thuan Beng.
3 Replies Last Post 11 oct. 2012, 17:59 UTC+2
Hello Thuan Beng Saw
Posted: 1 decade ago 12 oct. 2011, 12:47 UTC+2
I have the same problem with RF module. if someone knows the reason of this error or solved the problem already, it would be nice to share it here. (Tuan, did you solve this problem?)
H.A.
I have the same problem with RF module. if someone knows the reason of this error or solved the problem already, it would be nice to share it here. (Tuan, did you solve this problem?) Thanks H.A.
Posted: 1 decade ago 11 oct. 2012, 15:42 UTC+2
I have the same problem for my axisymetric SOFC model.
Posted: 1 decade ago 11 oct. 2012, 17:59 UTC+2
Hello, all,
Could any of you send a very simple example (better 2D) giving that error?
Jesus
Hello, all, Could any of you send a very simple example (better 2D) giving that error? Jesus
